F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
Old 11-06-2009, 08:05 PM
Vehicle: 1997 ford f150
Mig settings to weld a muffler?
just got a new muffler, i have a mig welder in my garage and i know how to weld i just don't know what settings to make it?
gas psi?
wire speed?
voltage?
it's a steel muffler
Old 11-06-2009, 08:53 PM
Vehicle: 2004 Ford F150
Gas flow is actually in cfh. Set to approximately 35 cfh.
Wire speed and voltage settings all depend on the type of machine you have. Does it have actual numbers or just letters and lines? I would suggest getting some scrap pipe and playing around with the settings.
B.S. Welding Engineering - The Ohio State University
Old 11-06-2009, 09:05 PM
Vehicle: 2006 Ford F150
No offence here, but if you have to ask that, I would let some else do the welding. Unless someone else here has the same exact welder as you, and is using the same type and thickness of wire... No one will be able to give you the best settings. Not even that, every welder has his/her own favorite settings depending on what he/she is welding.
2006 F150 XLT 5.4 4x4
Performance: Cheap ebay CAI w/ K&N filter, Delta Force tuning
Exhaust: Stock manifolds, NO cats, 2.5" true duals, Magnaflow X pipe, Original 40 Series Flowmasters, 3.5" stainless tips
Other mods: Nathan Airchime K3LA locomotive horns
Exhaust videos:
Idle, rev and hammer it!
Cruising by
Pulling up to an idle
Inside accelerating and cruising
Old 11-06-2009, 11:38 PM
well i just need to know what would be best for a pipe and a steel muffler lol , low wire speed since its thinner metal im guessing?, and its a miller millermatic 250
Old 11-06-2009, 11:50 PM
It's been a while since I saw one of those. That has the analog dials on it correct?
What is the scale for the voltage? I'm assuming that you're using .035" solid wire. Set wire feed speed to 190 ipm. Voltage around 17-19 volts. If it has the same dial set up as some of the older delta-fabs, set the voltage dial at approximately the 9:30 position. If it spits and sputters, slightly increase the voltage. Play around with that wire feed speed on a piece of scrap till you get the voltage set correctly. Set the voltage low so the wire will stub into the part intentionally and increase until it is a nice and smooth frying sound.
Old 11-07-2009, 12:49 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Yea .035. I just go by sound lol, feel fortunate you have gas. I flux cored my entire system lol. Just a hint, Ford does use a low grade stainless. As said -Practice piece first will set you up.
Old 11-07-2009, 04:07 PM
Vehicle: 2003 Ford F150
Send a message via AIM to migdaddy
you wanna use me to weld your muffler? that might hurt..
2003 F150 5.4. 20" Bazo B4 wheels wrapped in Nitto 420s. 3" Dynomax Bullet . K&N Intake. 2" rear drop shackles. 4:10 gears.
Bullet Start up/Rev
Bullet WOT
Old 11-08-2009, 12:11 PM
alright thanks, yeah i'll play with it
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
