F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
Old 11-03-2009, 11:59 AM
Stripped studs on factory 05 cast iron manifolds
I have an 05' F150 FX4 with the 5.4. I was removing the y pipe the other day and I guess someone put the nuts on the factory manifold collector studs too tight and stripped them. So when I go to remove the nut, it just spins. Well after alot of work, I got the nut off, but how do I replace the stud in the factory manifold? I tried to back it out by turning it, but it wouldn't budge. I really don't want to buy new exhaust right now. Help please.
Doug
Old 11-04-2009, 12:03 PM
anyone?? Surely someone has dealt with this before?
Old 11-04-2009, 12:39 PM
Vehicle: 2008 Ford F150
Send a message via Yahoo to EddiesF150
Lots of penetrating lubricant and let it soak in... then you can either weld a nut on the stud and try using a socket to back it out, or try Vise-Grips. If it still won't break loose, then take a torch and heat the boss surrounding the threads on the collector until it just starts to glow, making sure not to heat the stud itself, then try to back it out. It will squeak a little when coming out, but don't worry. Hope this helps!
2008 F-150 SuperCrew 5.4L PHP Gryphon tuned
2002 Explorer 4.0L / 1995 Ranger XLT 2.3L / 1994 Mustang Cpe 3.8L
1966 Mustang Cpe. A-code 289 4v 4 speed
Old 11-04-2009, 03:02 PM
I was unsure if they were a press in, a screw in, a knurled press in, or what. I don't think I could get a cutting torch up in there to get them hot enough to pop out, without burning something else.
Old 11-04-2009, 06:35 PM
Vehicle: 2005 Ford F-150
Send a message via Yahoo to batn68
Quote:
They are screw in, I used both vise grips and also two nuts backed up against each other if you still have any good thread left, and lots of penetrating oil.
2005 5.4L SCREW Stiegemeier Stage IV ported Magnacharger running @ 10 PSI
Dyno Tuned by Troyer Performance, Yukon 4.10's, FF Dynamics E-Fans
Pacesetter LTs, Maggie High Flow Cats, Y-Piped into a single 3" Borla XR-1
Videos of exhaust. http://www.youtube.com/watch?v=q3W6ZDz8D9Y http://www.youtube.com/watch?v=k1LgsBGxTSU
Old 11-04-2009, 08:15 PM
By the way, DON'T use a cutting head on your torch, use a welding tip... it has a smaller flame, and there's no danger of accidentally hitting the oxygen valve and cutting into the manifold...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
