F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
Old 10-29-2009, 05:16 PM
Vehicle: 2000 Ford F150
Send a message via AIM to BigBlue5.4
Performance: Out Back vs. Side
With my current exhaust, I've had both tailpipes and (now) dump pipes. It seems now that it has a little more down low. Would that be because the engine JUST has to push the gases past the muffler? If that is the case, then side swiping the exhaust would seem to be the better alternative. But, correct me if I'm wrong, the idea behind 2.25" true duals is the idea that the gases will flow easily still because that pipe size is just right for it. Any ideas?
(It could be that it's all in my head...but the physics make sense...)
Old 10-29-2009, 08:14 PM
Vehicle: 2006 Ford F150
You are talking tiny numbers on the dyno here. 2.25" has an increase in exhaust velocity that increases scavenging that increases low RPM torque. Larger pipe is better for higher RPM HP, but in our 6000 pound trucks, we could use a boost in the low RPM.
2006 F150 XLT 5.4 4x4
Performance: Cheap ebay CAI w/ K&N filter, Delta Force tuning
Exhaust: Stock manifolds, NO cats, 2.5" true duals, Magnaflow X pipe, Original 40 Series Flowmasters, 3.5" stainless tips
Other mods: Nathan Airchime K3LA locomotive horns
Exhaust videos:
Idle, rev and hammer it!
Cruising by
Pulling up to an idle
Inside accelerating and cruising
Old 10-29-2009, 09:57 PM
I understand all of that. What I'm asking is would have 5 more feet of tailpipe on each one effect power?
I will not be silent...Romans 1:16 ><>
2000 F150 Lariat 4x4
- 5.4L Triton V8
- 3.55LS
- Magnaflow High Flows
- 18" Magnaflow SIDO (dumped)
- AF1 CAI
Soon to come:
-2.25" X-Piped True Dual System with Borla ProXS Mufflers and 4"x12" SS Tips.
Old 10-30-2009, 06:39 PM
Vehicle: 1998 Ford Expedition
Big Blue: The questions that you ask are or could be complicated if an exact answer is required. There are some hairy Stochastic calculations that would require evaluating; possibly using thermal expansion graphs and velocity/viscosity coefficients.
That being said there are several theories and applications that you can refer to to answer your questions.
Here is what I know (I think):
With respect to scavenging the expended gasses of combustion (from the valve seats to the pipe end). For a given exhaust geometry ; the further back (rearward) on the exhaust pipe a muffler is placed the air column within the pipe will be more "reactive" . Tending to be more restrictive. This could occur or have greater effect at various points in the engine's power band.
The only reason that a less restrictive exhaust system "allows" more power to be generated at the motor is that there would be less resistance AND reactance to the transmission of the gaseous impulse generated at the piston. Doing so for a given geometry "would tend" to be more restrictive to the gaseous mass's velocity occurring at the input to the system. (Allows less power). This occurs because instead of acting as a transmission line [resistive impedance] the cavity volume of the total length of the pipe(pre muffler) comes into play{TT*r^2 x L}. This cavity behaves or has a "springy" characteristic in attempting to push the gaseous impulse backward into the valve cavity (Cylinder Valve). This would reduce the effective cavity volume of the cylinder upon opening at the intake (compressing)stroke. It would be assumed that having a larger pipe would be less restrictive in this geometry, but look at the formula in placing the values for the different size pipeage 2, 2.25, and 2.5" into that formula that the smaller pipe (within reason) reduces the net volume and lowers the pipe cavity volume. This could be used to "tune" an exhaust system with respect to sound and "flow". Since any work performed by the muffler with respect to the gas impulse has already been performed following the muffler it does little to cause restriction in the system. (within limits)
Now lets move that same muffler forward within the configuration. The air column in the input pipe if small is "usually" less restrictive AND reactive. The majority of the exhaust expansion occurs within the muffler and therefore this allows the gaseous impulse from the exhaust valve to be succepted at a higher rate. This is or would tend to cause a greater "scavenging" effect to the gasses. This is usually why OEM systems for trucks place the muffler either at the mid-point or further "up" into the configuration. The muffler breaks up the cavitation of the exhaust pipe volume allowing better flow.
For sound enthusiasts this permits the "sound" to be lower in level. Making the Exhaust note quieter at some given R/m's. In other words "Louder">> further back(but slightly more restrictive).
This geometry presumes a given muffler volume and porting. Flowmaster's type mufflers "tend" to have low restrictive effects when mounted "up" on the exhaust pipe. The cavity effect of the muffler when coupled with a short, "fat" pipe 2.5-3.0" tends to reduce both the restrictive, and reactive effects of such a system.
This would "tend" to be less restrictive over a greater range of R/m's.
Now considering how a muffler works the gaseous impulse following the muffler has been smoothed significantly from a pulse to wind (within limits) and this volume velocity has been reduced significantly.
The pipe out of the back or side will have less effect on the net restriction of the exhaust system. So dumping the output of the muffler or running a reasonable amount of muffler pipe would "tend" not to have a negative effect on such a system.
>> If you want to increase the net sound output of a given muffler system figure on moving the muffler further back on the exhaust pipe (maybe behind the differential) and shortening the trailer pipe as required. However if you need to pick up some needed hp and torque arrange the system to mounted as far front as possible to the engine or cat's and then dump the muffler outputs as best that can be done. Increase the output diameter of the muffler exhaust pipe by at least 1/4" to 2.5" dia. and drop it behind the differential as desired. It is more important to have as few significant bends in the pipe minimized following the muffler. Or as best as can be done within reason.
However if you have a Navigator or Expedition it would dump the exhaust out the sides behind the wheels.
Entropy Enhancement:
You can pick up a significant improvement an any exhaust system by keeping the net volume of gas as hot as possible before the muffler. Wrapping the exhaust headers , lead pipe with Thermo Tape can improve output and flow by 7-15% on average. Good value improvement.
Paint or coat your headers "Silver" (not the Cat's) and input pipes with good grade Header Paint can also improve the system thermodynamically to give an improvement.
I'm open to discussion if you want. I didn't think I would have posted this long (sorry).
Peaze
SAE, Society of Automotive Engineers
AES, Audio Engineering Society
MACS, Mobile Air Conditioning Society
Old 10-30-2009, 07:01 PM
Vehicle: 2003 Ford F150
Send a message via AIM to migdaddy
ill give someone a dollar to read that whole thing ^^
2003 F150 5.4. 20" Bazo B4 wheels wrapped in Nitto 420s. 3" Dynomax Bullet . K&N Intake. 2" rear drop shackles. 4:10 gears.
Bullet Start up/Rev
Bullet WOT
Old 10-30-2009, 07:09 PM
Pay up! lol Very interesting read!
Exhaust videos:
Cruising by
Old 10-31-2009, 04:07 AM
Vehicle: 2004 Ford F-150
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Quote:
my paypal is the same as email
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Painted Headlamps/Fog lamps, 20% Tint
Performance: PHP Gryphon 87 Perf, 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks, 20x9 XD Monsters, 33x12.5 Toyo M/Ts
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone Tunnel Carwash Rev
Old 10-31-2009, 08:25 AM
mine to!!!
Exhaust videos:
Cruising by
Old 11-17-2009, 11:02 PM
let me holla at a dolla too!! quiz me...
[IMG]Please re-size sig image to 500x100. (S)[/IMG]
2008 4x4 CrewCab XLT 5.4L, 6" Fabtech, 2.5" AS, 2.5" AAL, 35x12.5x18 Toyo MT's, 18" Mazzi Hulks, U/D pullies, AirForceOne CAI
Old 11-19-2009, 05:06 AM
^^^ fail
Bullet Start up/Rev
Bullet WOT
Old 11-19-2009, 01:43 PM
Vehicle: 2006 Ford F-150
so let me see if i understood that right.
Closer to the engine and hotter exhaust means more HP but less sound?
Farther from means more sound?
So a good balance for my truck ( and what I want ) would be slightly closer then stock, with a behind the wheels tips ( SI/DO ) for a good sound and still the same or slightly better HP/TQ.?
2006 F-150 5.4L XLT. Supercab 2X4.
Old 11-19-2009, 03:38 PM
Peaze
LOL...where's the cliffs for this?
j/k
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
