F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
Old 10-24-2009, 09:12 PM
intake/exhaust advice
truck is a 2007 xlt screw, 5.4. it came with a gibson si/do and i recently threw some 35's and an edge evo on there
1) is there a big enough performance gain (if any) to warrant the hundreds of dollars it would take to have a completely custom dual exhaust w/hi flows, mufflers and all, or should i just stick with what i have and be money ahead. the sound to me is perfect, and performance seems to be pretty good too (not sluggish at all)
2) also, im about to pull the trigger on a cai set up and upgrade to the gryphon custom tuner, and ive been looking at the spectre 4" intake and the volant. i know the volant is completely encolsed, but the spectre is $200 less. sometime soon i will be most likely getting the reflexions cowl hood, so is the volant really worth the extra $200 to have the "true" cai?
Old 10-24-2009, 10:02 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Exhaust makes a minimal performance upgrade. It does not make any more engine power, it just helps it exhale more which in return helps it run better, and sound unique.
In your case I would keep it single, or if you must change to duals go with dual 2.25" off the cats.
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Painted Headlamps/Fog lamps, 20% Tint
Performance: PHP Gryphon 87 Perf, 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks, 20x9 XD Monsters, 33x12.5 Toyo M/Ts
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone Tunnel Carwash Rev
Old 10-25-2009, 12:05 PM
Vehicle: 2006 Ford F150
I bought a cheap CAI off of ebay for $80, and I could tell a difference with it.
2006 F150 XLT 5.4 4x4
Performance: Cheap ebay CAI w/ K&N filter, Delta Force tuning
Exhaust: Stock manifolds, NO cats, 2.5" true duals, Magnaflow X pipe, Original 40 Series Flowmasters, 3.5" stainless tips
Other mods: Nathan Airchime K3LA locomotive horns
Exhaust videos:
Idle, rev and hammer it!
Cruising by
Pulling up to an idle
Inside accelerating and cruising
Old 10-25-2009, 12:06 PM
http://cgi.ebay.com/ebaymotors/COLD-...Q5fAccessories
Exhaust videos:
Cruising by
Old 10-25-2009, 12:07 PM
Disregard that first link. Mine came with a K&N brand filter too. I don't think that this one does.
Exhaust videos:
Cruising by
Old 10-25-2009, 12:12 PM
Vehicle: 1999 Ford 5.4L F150 4x4
1. Leave your exhaust be unless you want a difference sound. You won't be able to tell the difference in power an exhaust change makes. Very minimal.
2. Haven't heard anything about either being dynoed by one of the tuners (as far as gains), but any intake with a tune will be leaps ahead of the OEM setup.
I'd spend the money on gears for those bigger tires. That's a mod. you'd definately be able to tell the difference...
| PI Heads | Platinum & Amsoil | ScanGauge II | Factory Tech Sep. Plate |
| BBK UD Pulleys | AF1 w/ ram air & heatshield | deleted rear cats |
| mandrel bent true dual straight pipes w/ H-pipe | 3.5 x 18" rolled Silverline tips |
Old 10-25-2009, 12:52 PM
thats kinda what i was thinkin, but i just wanted to confirm, cause i hear everyone talking about duals duals duals
as far as gears, i know thats gonna be the best way to get my power back, but its cost prohibitive for a little while
Old 10-25-2009, 06:14 PM
avfrog, is it safe to assume yours bolted right up, no problems? i just thought that one looked kinda cheesy, like it may require some modifications to work right
2007 XLT Supercrew 4x4 Blackout
2.5 hell bent steel 315/70/17 Xtreme MT on V-Tec Raptors
edge evo & a gibson si/do
20% tint & a whole lotta black spray paint
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
