F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
Old 10-23-2009, 01:01 PM
Vehicle: 2003 Ford F150
URGENT!!! HELP!! TB clean, poweraid delete
Hey guys, gimmie a hand. I'm cleaning my TB on my 03 SCREW 5.4L and also wanted to get rid of the Poweraid TB Spacer that came with the truck when I bought it. Its not doing anything for me, and MAY actually be hurting my MPGs.
PROBLEM: Obviously they have longer bolts because of the spacer. What bolts do I get if I remove the spacer??? Part #????? I've taken the first piece off (forgive me as I don't know all of the technical terms) but I need the bolts that bolt up the piece with the butterfly to the main body...if that makes sense. Here are some pics that may help....dirty isn't it!
----DirtySCREW
03 SCREW FX4 Lariat 5.4L, AirForce 1 CAI, Poweraid TB spacer, 14" Magnaflow SIDO
I'd rather be judged by 12 than carried by 6!
Old 10-23-2009, 01:02 PM
Here's a pic of the POS TB spacer:
Old 10-23-2009, 01:58 PM
Vehicle: 2006 Ford F150 XLT
Just leave it on. I can't see any way for it to hurt your performance, but it won't help either.
2006 Ford F150 XLT - 281ci V8 - Regular Cab/Flareside - 2WD
True Dual Magnapack Exhaust - Gott's CAI - Edge Evolution Programmer
Mustang Exhaust Exhaust Interior Drive By
Old 10-23-2009, 02:03 PM
Vehicle: 2009 Ford F150
+1 they actually improve performance. Not by a lot but 1 mpg is 1 mpg. I wouldn't mess with trying to find the right bolts if I didn't have to.
Old 10-23-2009, 02:17 PM
I guess I'm gonna have to. I was gonna sell it on CL and use that $$$ toward my exhaust. Oh well...no sense in looking for bolts today cause I need to hurry up and get in the woods. Mr. 8 Pointer is calling my name, "Dirty....come shoot me!" HAHAHAHA---------DirtySCREW
Old 10-23-2009, 02:56 PM
I couldn't get the TB off as a hose kept squirting coolant all over my engine. I just sprayed the TB cleaner inside and wiped and wiped and wiped and wiped until it was shiny again. I don't have time to do it right...but I know its a LOT cleaner than it was and SHOULD help my MPGs. I hope anyways. I'll post some of the clean pics as well. I couldn't get off the IAC (whatever that is). The screws were dead tight even after I quirted PB Blaster on them a few times. They were getting ready to strip so I quit while I was ahead. Now I have to reassemble eveything. OH, I also clean my MAF with some MAF cleaner.---------------DirtySCREW
Old 10-23-2009, 06:22 PM
Quote:
Actually, it gains you 0 MPG and 0 HP. The only use for it is to make the engine bay look pretty, and a nitrous port.
Old 10-23-2009, 10:31 PM
Here she is ALL cleaned up:
I do have one question. Obviously it took a little while to get the truck cranked as about half a bottle of TB cleaner flooded it out. Once I did there was a little white smoke (I'm guessing a mini-Seafoam show...I dunno..never used sea-foam before).
My question is there is/was a annoying whining sound coming from my intake. It was a high pitch "shrill"....possible coming from MAF. If you gave it the slightest amount of gas it would quit. Back at idle, it would come back. I have to see if it is still there tomorrow. Also, why is my battery light coming on at WOT?? My truck has so much MORE get up and go. My pants dyno is HAPPY!!!! Just hope my MPGs start going up----DirtySCREW
Old 10-23-2009, 10:48 PM
The whine is probably from the spacer. It will eventually stop when carbon starts caking back on everything again.
Old 10-23-2009, 11:09 PM
4.6---I dunno.....it really sounded like it was coming from the air filter/ MAF area. I keep ya updated--------DirtySCREW
Old 10-24-2009, 11:43 AM
Vehicle: 2004 Ford F150
Send a message via AIM to TruckGuy24
I have heard that complaint about throttle body spacers... you should be ok
John
Thanks Watson91 at S-FX
PTM Century Tonneau
Remote Start
14" si/do Magnaflow 45'd behind rear tires
4" x 18" SS Tips
Roush Grille
Billet Bumper Grille
PTM Mirror caps
DVW Intake w/ K&N drop in
Quote:
Originally Posted by 05RedFX4 View Post
Best of luck to you, and hopefully you don't have the same attitude when you go into the dealer to get your trans fixed, because if you do your gonna need a big jar of vaseline cause they are gonna stick it to you, HARD
Old 10-24-2009, 03:07 PM
Vehicle: 2003 Ford F-150
Quote:
look pretty you can't even see them unless your looking for them, they sure do make a good conversation starter.
Old 10-24-2009, 10:15 PM
Well guys, I drove my truck today about 20-25 miles round trip and no annoying noise...thank God! I dunno what it was. I had never had that moise before and of course the truck had the throttle body spacer. If I had regular bolts, I would have actually removed it..but oh well. My truck seems a lot more "alive" and more responsive. I also reset the ECU by having the negative battery cable disconnected for about 2.5 hours while I did everything. Maybe all the little things are adding up---DirtySCREW
Old 10-24-2009, 10:40 PM
Vehicle: 2000 Ford F150
Send a message via MSN to Gotts2BMe
you should have ported that up while you had it apart...
Stock
Ported
takes it from 65-70mm
also the elbow
To get the bolts, go to a wrecker and see if they have any of te trucks laying around, pop the 4 bolts of and there you go.
Also your battery light is flickering because your alternator is on its way out. Expect to be changing that within a couple months
Gotts Intake with K&N - OBX Long Tube Headers - Magnaflow 15749 - DIY Efans - MAC UDP's - Troyer Tunes - 75m TB - Ported intake - 33" Firestone Destination M/Ts
220,000+ Miles
Old 10-24-2009, 10:47 PM
Gotts---forgive my ignorance.....but what does porting your TB do?? And thanks for the heads up on the alternator.---DirtySCREW
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
