F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
Old 07-02-2009, 07:24 PM
Vehicle: 1998 ford f150 4x4
help!!! my truck is being weird after my carb cleaning
i cleaned the throttle body. put it back together. i went to test drive it and it was acting weird... it doesnt shift when its suposed to, instead it revs really high and higher! untill i just let off the gas and it finally shifts. also it doesnt go into a higher gear (from 4th to 3rd ona hill) unless the rpms get SUPER low, or if i tap the breaks. anyone know what this is?
Old 07-02-2009, 08:01 PM
Vehicle: 1998 Ford F-150
Quote:
Originally Posted by xxs0ulxx View Post
i cleaned the carb.
Throttle Body? Did you use a Cleaner safe for O2 sensors and catalytic converters?
Old 07-02-2009, 09:45 PM
What year truck, what engine? It sounds like a kick down linkage problem or a vacuum line off of the modulator on the trans.
Old 07-03-2009, 05:42 PM
i used car throttle body cleaner so i guess it was safe, my truck is 1998 f150 4x4 4.6l. how do i know if its a wire messed up? or what... it sucks.
1998 4x4-coldair int.-Shorty's Headers-no rear cats-Throtle spacer-Programed-duel flowmasters-e-fan conversion.
http://s476.photobucket.com/albums/r...ent=nop009.flv
Old 07-03-2009, 05:45 PM
oh, and i took off the throttle body so the engine didnt get any throttle body cleaner in it.
Old 07-05-2009, 07:10 PM
Vehicle: 1993 ford f150 xlt
Quote:
his is electronically controlled. no vacuum modulator or kickdown cable.
did you take the tps off the throttle body? if so did you put it back on properly? plug it back in? kinda sounds like you put it on wrong, or left it unplugged. it is suppose to be set on the tb so that the throttle moves it.
Old 07-06-2009, 10:29 AM
so matt how might i know which is the tb cable or plug in.?
Old 07-06-2009, 04:30 PM
just look at the sensor, if its plugged in then pull it off. or use a voltmeter and see if the signal voltage goes up with throttle movement. if it doesnt change then pull it off and make sure it still looks good. then set it on the tb so that it turns with the throttle.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
