F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
  #121
Old 10-11-2008, 12:17 PM
Vehicle: 2000 Ford F150
Send a message via MSN to Gotts2BMe
Quote:
Originally Posted by JNC995 View Post
Heck man, I have an 04 black FX4 with 60k miles I'll sell you for 13.
Back to the Gotts intake. Thinking about doing this tomorrow. Kind of confused, but I think its b/c I haven't taken my intake off before.
Anyway, Let me know if I have this correct please.
I take off the original piece that goes into the fender.
Put piece of PVC pipe 1/2 into coupler. Connect with hose clamp.
Then jam the pvc pipe into fender hole.
Then connect other side of couple to rest of stock intake.
If this is correct, how long of a piece of pvc and coupler do I need? How far do I stick the pvc into fender, and how far do I stick pvc into coupler?
you should find it laid out nicely here...
http://www.fordf150.net/articles/idx...ification.html
Gotts Intake with K&N - OBX Long Tube Headers - Magnaflow 15749 - DIY Efans - MAC UDP's - Troyer Tunes - 75m TB - Ported intake - 33" Firestone Destination M/Ts
220,000+ Miles
  #122
Old 10-11-2008, 12:27 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
Quote:
Originally Posted by valleyfreak45 View Post
does or has any done this on a new body style 5.4L?
Quote:
Originally Posted by sharpshooter109 View Post
does the new style 5.4 have the right type of airbox for this mod? i thought i read somewhere that they re-designed it. ill start looking it up.
NO this will not work on the 3 valve 5.4 engines due to the redesigned air intake tubing
if anyone is messing with a 3 valve engines air intake system do not do it until you get a custom tune
  #123
Old 10-11-2008, 01:05 PM
Vehicle: 2002 Ford F150
Took me a second to understand, but got it now. Gonna do this afternoon.
Lowe's had a 3" piece of aluminum piping, for lamp post, wonder if that would work? I just got the pvc, smallest piece was 2", so going to have a lot extra.
On a side note, how do you like that k&n filter? I just got the purculator plus, it was 25, and the K&N was 56. Is it worth the difference? How often do you have to oil/clean that thing?
2002 F150. 5.4L Stock except for tbars cranked and 33's.
  #124
Old 10-11-2008, 04:28 PM
1. Gotts2BMe 16. ridethlightning
2. terajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7.jughed
8.jbrew
9.cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13.BroncoWrench
14.JMoreland
15. sharpshooter109
'94 lightning
'08 f150 e-cab sb
  #125
Old 10-11-2008, 05:47 PM
Any of you guys actually use a file? I've been filing away for ever, and there is no way I'm going to be able to get that pipe 2" into the fender. Guess I'm going to have to buy a dremel or something.
One question with the hole in the fender. Does the stock intake take much air from the first void, just wondering b/c it seems that one will be covered if you shove the pvc 2" into the fender.
  #126
Old 10-11-2008, 06:01 PM
Vehicle: 200? FORD
I cut a chunk out of one I did so the pipe wasn't completly round. I only went in about 3/4 inch
the first one I filed for days... let me try to dig up a picture someplace
  #127
Old 10-11-2008, 11:03 PM
Vehicle: 1998 F150
i tried using a file. gave up. used a cheap knock off dremel. gave up. used the dremel piece in a drill. gave up. used a sawzall to cut some off the top. gave up. finally i dug up an old as dirt belt sander out of our basement. got half way done and broke the belt. had to drive to home depot and get another. that belt sander really did the trick! it took me a total of like a month from start to install.
exhaust vid
  #128
Old 10-12-2008, 01:57 AM
Well picked up a dremel. Got the pipe to stick. Not gonna get it 2" in though, so I'm going to have to trim off about 1.5" from the back. Got dark on me, so going to finish in morning. Hopefully leaving the intake open all night wont mess anything up. Put a drape over it. Hope that works. Dremel works pretty good. Just doesn't look to clean.
  #129
Old 10-12-2008, 10:31 AM
2. terajerame 17. JNC995
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7.jughed
8.jbrew
9.cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13.BroncoWrench
14.JMoreland
15. sharpshooter109
  #130
Old 10-12-2008, 10:11 PM
Vehicle: 1998 F150
exhaust vid
  #131
Old 10-12-2008, 11:56 PM
Vehicle: 2001 Ford F150
Sounds good. That is what I was thinking of doing to my truck.
  #132
Old 10-14-2008, 03:57 PM
Still haven't ried the tume up. do you think the PCV valve could caus the missing?
  #133
Old 10-14-2008, 04:02 PM
How do you do the signature or put a picture of your truck at the end of each post?
  #134
Old 10-14-2008, 04:55 PM
Vehicle: 2003 Ford F150 FX4
1. Gotts2BMe
2. terajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
  #135
Old 10-20-2008, 05:26 AM
Vehicle: 1998 Ford F150 4x4 5.4L
I'm not understanding - what's with the 2" stuff ??
I used a Milwaukee 1/2" drill motor and a 3" carbide hole saw attachment...
Just hang on for life when you hit the go trigger - Don't let go now
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
