F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Exhaust & Intake Systems
Exhaust & Intake Systems SPONSORED BY:
Thread Tools Display Modes
  #46
Old 11-29-2007, 11:29 PM
Vehicle: 1998 Ford F150 4x4 5.4L
Quote:
Originally Posted by dleebold
Well, that's interesting. I'll have to try that - I didn't think they where adjustable. Well, I have a 99 TB on mine now - maybe that one is - if not , I'll make it adjustable if it's higher than 99 on the voltmeter ..
Thanks for posting
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Ported & Polished Intake/TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Volant Intake w/Amsoil EEA191 Filter, 265/17 GY Fortera's.
  #47
Old 12-01-2007, 12:11 PM
Vehicle: 2004 ford f150
jbrew;let us know how the tweak went.
  #48
Old 12-04-2007, 08:53 AM
I'll do that I have to get a better volt-meter , I haven't went to digital yet
Christmas is around the corner- I think I'll treat myself while I'm out hunting down a few gifts. I'll look for this thread or post up a new when I do her.
Anyone else do this ? I haven't seen this before on this site, have on others. I was just wondering why ? I realize that some TPS Sensors are the non-adjustable type , but they can be made adjustable which is probably what I will have to do to obtain said results from past posts.
Please post up if there's unwanted repercussions from attempting this mod ..
Thanks, jbrew
  #49
Old 12-04-2007, 10:06 AM
Vehicle: 2004 ford E-250
[quote=jbrew]I'll do that I have to get a better volt-meter , I haven't went to digital yet
Thanks, jbrew[/QU
i had an 01 dodge ram 4x4 360 that i did this too-drilled out the brass bushings that the bolts went through to mount it-this gave it some "adjustabilty"mine was way off set it to optimum voltage- night and day in throttle response-phil
2004 E Series Super Duty
-Troyer Performance tuned x-cal 2
-ASP Underdrive pullies & Goodyear Gatorback Belt
-Magnaflow 2 1/4" SS, x-piped,mandrel bent dual exhaust-#14335 mufflers
WWW.TROYERPERFORMANCE.COM
2006 Honda CBR1000RR-157.2 rwhp,82.5 ft.lbs.tq
2010 Honda crf 450r's-+25,Vet A,+40A
  #50
Old 12-04-2007, 12:45 PM
Quote:
Thanx Phill
  #51
Old 12-04-2007, 02:07 PM
Quote:
Originally Posted by jbrew
Thanx Phill
anytime jbrew!-phil
  #52
Old 12-05-2007, 12:08 AM
Vehicle: 2002 F 150 ext cab
Tps Mod Done!
Just got done with the TPS adjustment. original voltage= 1.13. new=.989
benefits: increased smoothness of idle . throttle response is better than it was. I used two safety pins bent at 90 degree angles to reach behind the plug to read the wires out.
the TPS screws were on there pretty tight, and had to use some liquid wrench on them. Whose idea was this anyway? thanks whoever it was!
  #53
Old 12-05-2007, 05:46 AM
WOW!! GREAT!!
Thanks for posting.. - So that's worked for two here so far , I'm doing her ASAP.
  #54
Old 12-06-2007, 11:36 PM
Vehicle: 1999 Ford F150
Has anyone tried this on a 4.2 engine? I am talking about the intake mod. Thanks Ben
  #55
Old 12-07-2007, 01:41 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
Quote:
give it a try and see how it works
  #56
Old 12-16-2007, 11:38 PM
Got rid of the factory intake in my Expedition today! The factory intake is over 4" where it goes into the air filter but only 2.25" where it comes through the fender well. I replaced it with a piece of 4" thin wall Sewer pipe, a 4" to 3" adapter and a piece of 3" through the fender well. The Ex seems to breathe a lot easier now and there is no noticeable difference in noise!
  #57
Old 12-16-2007, 11:57 PM
um.. where is your filter? pcv pipe absorbs a LOT of heat FYI
  #58
Old 12-17-2007, 12:00 AM
Send a message via AIM to MmmBuckles
Quote:
ya really. i hope you havent been driving around without a filter
  #59
Old 12-17-2007, 01:42 AM
The 3 valve motors have a Cartridge filter. Right below the 5.4 in this pic is one of the clips that hold the filter in. The big can i took off was a silencer. As far as heat goes it shouldn't be any different the the heat that the big plastic can would hold. Now there is a LOT more room for air to move around. It just so happens i bought a Scanguage so i will be able to see the Intake Air Temps with the factory setup and with this one..............
  #60
Old 12-17-2007, 10:56 AM
Vehicle: 2000 Ford F150
"The 3 valve motors have a Cartridge filter."
- Had me worried for a second
does that silencer have slits in it or are those ribs?
did this gotts mod last night, yet to drive the truck. should i see a difference on the SOP dyno??
1. Gotts2BMe
2. terajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7.jughed
8.jbrew
9.cookdawg06
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
