Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Excursion
Thread Tools Display Modes
Old 06-05-2005, 09:02 PM
ckm ckm is offline
knock in the floor boards
new here so bare with me 2003 excursion limited with a knock coming from under the truck when driving dealer replaced all body mounts, knock still there then said there was a tsb to use epoxy metal weld on a rivet or some bs probably should have asked for the tsb # oh well anybody ever hear of this thank ckm
Old 07-17-2005, 07:04 PM
Knock in floorboard
Quote:
In reply to CKM, I have a 2004 Excursion with a similar problem. The first time in for service, the dealer took apart the telescoping steering column and regreased it. This solved the problem for about three days but the knock under the floorboard returned. The dealer then replaced the steering column completely. Still had the knocking noise. The dealer sent the Excursion to the body shop where they replaced all of the body mounts. Still the knocking noise was there. I am in for the fourth visit and admitadely they cannot find the source of the noise. I will post the results if and when they figure it out.
Old 07-22-2005, 01:32 PM
Vehicle: 2001 Ford F150
Well, my husband's 2000 Excursion had the same problem and he did a little research on the Excursion forums and found out that it is a loose body mount...just needs to be tightened. Apparently it's a common problem, and it will loosen again in time.
Old 07-24-2005, 09:33 AM
ckm ckm is offline
thanks for the info the epoxy repair lasted like a week.I am going to try another dealer when i get time.My body mounts were also replaced.Its kinda odd that more people dont have this problem being that the excursion is based on th f250 or 350 i can never remember.Anyway thanks again for your responses. ckm
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
