Excursion
knock in the floor boards
Old Jun 5, 2005 | 08:02 PM
ckm's Avatar
ckm
new here so bare with me 2003 excursion limited with a knock coming from under the truck when driving dealer replaced all body mounts, knock still there then said there was a tsb to use epoxy metal weld on a rivet or some bs probably should have asked for the tsb # oh well anybody ever hear of this thank ckm
Old Jul 17, 2005 | 06:04 PM
apark's Avatar
Knock in floorboard
In reply to CKM, I have a 2004 Excursion with a similar problem. The first time in for service, the dealer took apart the telescoping steering column and regreased it. This solved the problem for about three days but the knock under the floorboard returned. The dealer then replaced the steering column completely. Still had the knocking noise. The dealer sent the Excursion to the body shop where they replaced all of the body mounts. Still the knocking noise was there. I am in for the fourth visit and admitadely they cannot find the source of the noise. I will post the results if and when they figure it out.
Old Jul 22, 2005 | 12:32 PM
meldyer's Avatar
Well, my husband's 2000 Excursion had the same problem and he did a little research on the Excursion forums and found out that it is a loose body mount...just needs to be tightened. Apparently it's a common problem, and it will loosen again in time.
Old Jul 24, 2005 | 08:33 AM
ckm's Avatar
ckm
thanks for the info the epoxy repair lasted like a week.I am going to try another dealer when i get time.My body mounts were also replaced.Its kinda odd that more people dont have this problem being that the excursion is based on th f250 or 350 i can never remember.Anyway thanks again for your responses. ckm
