Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Excursion
Thread Tools Display Modes
Old 04-16-2003, 01:43 PM
Vehicle: 1999 Ford F150
Recirculating air
I have a 5.4 Excursion XLT with a manual A/C. Can anyone tell me how to set the heater/AC to recirculating warm air, so that when I'm driving at 0 degrees behind a stinky diesel, I can shut out those fumes?
Thanks for your help.
Ray
Old 04-20-2003, 10:53 PM
Vehicle: 1999 Chevy Silverado
Max AC with the heater selector all the way to the right..
That should do it for you!!
Hope this answers your question..
FordMasterTech
Technical Consultant
Old 04-21-2003, 02:58 PM
Tried that setting and all it does is blow cold air. It works like that on the AC setting but it doesn't recirculate the air that way. Do you think the system is not properly?
Old 04-23-2003, 08:20 PM
Sounds fishy to me.. Does it have the EATC (automatic temp control ? )
FordMasterTech
Old 04-23-2003, 08:22 PM
Disregard..
Looked an saw that it was manual, sorry@!@
Does the heat work at all?
I have used the setting that you desire driving My Explorer Sport.
Sounds like something isn't working properly..
FordMasterTech
Old 04-23-2003, 08:26 PM
I don't know where my mind is today..
So, what I BELIEVE is happening is that the blend door will not stay in the full heat during MAX AC.
Maybe they are made that way, but it still sounds fishy.
I will do some investigating into this issue and compare another Truck to what you are describing.. I'll post when I make the comparison..
FordMasterTech
Old 04-24-2003, 02:22 PM
Your help is highly appreciated.
Ray
Old 05-14-2003, 10:03 PM
Vehicle: 2008 Ford F150
I have the same truck, and if "manual" AC means you manually adjust it, not electronically set, then we have the same thing. It SHOULD produce heat in the AC setting if you have the dial in the red. If not, there IS something wrong. I have found that if I want the AC or Heat to work even quicker that using the REAR AC/HEAT at the same time makes it get cold/warm quicker. Good luck.
2008 F150 4x2 S'crew XLT, 4.6L, V8 BRIGHT FRIGGIN RED!
Bad Azz Girls drive Bad Azz Trucks!
Old 05-14-2003, 10:04 PM
Oh yeah, and you can also try PASSING THE DIESEL! (sorry, couldn't resist!)
Old 05-15-2003, 11:08 AM
We have the same thing as we have the same truck I guess. Does the A/C produce heat when the dial is set to MAX AC and the temperature selector dial set in red on the dashboard? Does it blow heat that way out of the front registers?
Thanks for your reply! I need it to fight my dealer to fix it if it is not working correctly.
Ray
Old 05-15-2003, 11:14 AM
Oh yeah..passing the diesel is kinda hard to do when the A/C ices up the windshield trying to keep those nasty fumes out of the truck....I think....Not?
Ray
Old 05-15-2003, 01:09 PM
Yes, MAX AC does produce HEAT when the dial is in the red out of all open registers. Same thing for the rear vents.
Old 05-15-2003, 08:03 PM
Thanks a lot for your help, Claudia, it is very much appreciated.
Ray
Old 05-15-2003, 11:45 PM
No problem. I'm just glad I could help.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
