Only very light surface rust – No body/frame damage due to rust
New Bed liner
120V A/C Block Heater
Privacy Glass
Trailer Tow mirrors
ABS with 4 wheel Disc Brakes with new pads and rotors
Issues:
Missing fusebox cover, seatbelt cover and radio antenna.
Automatic transmission shifts erractically. Still driveable, but it seems as if there is a line pressure adjustment or else the tranny and/or torque converter needs to be replaced. Could be a relatively cheap fix or expensive. Not quite sure.
When you turn the truck off, the accessory belt squeaks. It’s in need of a new belt, but that is an easy fix.
Other:
Truck starts up everytime. Never had a problem starting it in cold temperatures. The truck doesn’t use glow plugs as it uses a matrix grid heater in the intake and it seems as if it working great because I was able to easily start it up in 32F weather. The engine idles properly, turbo spools great, no check engine lights, and no questionable powertrain noise (ie: valvetrain noise, connecting rod noises, etc). The truck is in great shape, it’s got new 10 ply “E” rated tires, new brakes all around. The paint in excellent condition for its year. There are some minor nicks and scratches, but nothing major.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
