Door Lock Wiring!!!!
Okay, jokes over....I am having one heck of a time finding the lock/unlock wires to attach to my new remote starter. I bought the Crimestopper V, and have EVERYTHING done except for the stupid door locks. I pulled the boot off on the driverside door, and for the life of me....those wires just disappear after they go into the firewall. It's been two days now.....wife is losing faith in my ability. I need specific location of these wires (picture would be awesome). I have a 97 lariat, with keyless entry. That should take a reversing relay setup...right? I would like to get both doors to lock/unlock together if possible. Any help would be greatly appreciated!!!
Thanks...
Mike
Thanks...
Mike
Local Installer
Hey,
I am deployed to the desert of AZ right now, but I am in the spare time a Car Security Dork..
The wires you are looking for if the vehicle has door locks are located to the left of the steering under the dash. There is a small box on the firewall wit I think 2 connectors. You will find your wires here. If you go to your local installer (preferably a good one) they will print you off a location and color code chart.
Good Luck
Nate
Good Luck
Nate
wiring
WIRE COLOR LOCATION
12 VOLTS CONSTANT YELLOW(2) OR LT GRN/VIO IGNITION HARNESS
IGNITION 1 D BLUE/ GRN IGNITION HARNESS
ACCESSORY/HEATER BLOWER 1 GRY/YEL IGNITION HARNESS
ACCESSORY/HEATER BLOWER 2 RED/BLK IGNITION HARNESS
STARTER RED/LT BLUE IGNITION HARNESS
PARKING LIGHTS BROWN(+) AT HEADLIGHT SWITCH
DOMELIGHT BLK/L BLUE(+) PASS KICK PANEL
PWR DOOR LOCK PINK/YELLOW DRV OR PASS KICK PANEL
PWR DOOR UNLOCK PINK/L GRN DRV OR PASS KICK PANEL (TYPE C)
TACH SENSOR WHITE/PINK AT PWR CON MOD
BRAKE LT GRN(+) SWITCH ABOVE BRAKE PEDAL
HORN D BLUE(-) STEERING COLUMN HARNESS
FACTORY DISARM D GRN/PURP DRV KICK PANEL
PLEASE NOTE: If the last line in the above chart contains an entry - FACTORY ANTI THEFT and its value is Passlock1, Passlock2, Vats or Transponder, you have to buy the bypass module 791.wiring harness codes
