Backup lights
Believe it or not, I'm having difficulty finding the part (backup light switch). I've been to several of the local auto parts stores, who said they have the part but when they bring it up, it looks nothing like the part. I've called dealers, who say they can order it, but it's kinda expensive, about $75.00...sheesh.
Anyone know of any websites where I can order a part like this.
Backup Light Switch
I was looking in my 87 Mitchell Manual for the backup light switch when it dawned on me. If yours was a manual trans, like my 87 Ranger, there is a small 2 wire switch mounted on the left side of the trans.
With an auto trans, the backup switch is actually part of the gear select switch which should be part of the shift linkage that goes into the trans on the left side.
Don't panic about the part I said "part of the shift linkage that goes into the trans'' as you can remove the switch from the outside.
What you can do to test the switch is to disconnect the electrical connector from the switch (should be about 6 wires) and jumper the Purple/Orange with the Black Pink. Turn on the ign switch.
If the backup lights are now on, the switch is out of adjustment or bad.
If it starts ok now, the switch is not out of adjustment, but bad.
(the backup light part)
Remember, the backup lights get power from fuse #5 which also powers up the directional lights. So if they are working, you can check for power at the Gear Select Switch with you test light on the Purple/Orange wire if you want to be sure there is power there.
As I said, if you jumper the two wires and the light comes on, the switch is bad.
Hope this helps.
Mike C.
Hope this helps.
Mike C.
I had a similar problem with my 88 F150 but it was with the taillights/blinkers not working. Replaced both bulbs and checked to make sure the fuse had continuity. After troubleshooting with my DMM, I found faulty wiring. The ground wire was heavily corroded causing the wire to have high resistance. The 12 Volts was present at the plug until the circuit was loaded (brake applied or blinker turned on). I ended up cutting out the ground wires and replacing them.
-Matt
-Matt
