no signal lights but hazards and brake lights work fine
i have a 2004 F150 my signal lights just stopped working both at once no dash indicater either my hazard lights and brake lights work fine when you press the brake and flick the signal switch the brake light on that side blinks once i checked the fuse it was fine i changed the flasher still no dice everything else on the multifunction switch works fine just no signal could the switch be the culpret ?? if so can a regular steering wheel puller work or do i need a two hook puller ?
i replaced the switch today no dice still same problem im wondering if the flasher i got and replaced is maybe the problem i seen a youtube video and the guy used the same part number flasher as the one i got but it might not be compatible how do i find out ?? my original part is 4l3t the new one is 5l3t ??
