Blower motor runs with key off
I would look for a stuck relay. (I don't know if that model uses a relay but that's where I would start.) Do you have an electrical service manual? If not, get one.
Does the fan control vary the fan speed or does it always run at the same speed? Have you pulled the fan fuse to see if that stops it?
on
Probably "Leaky Windshield Syndrome". This is one of the typical problems associated with water in the fuse box and the GEM module.
on
signatures are not always shown ( UserCP option ).
Allie's Man -> You did it correct from the start.
Some members here are too used to members not providing the info and don't look.
- Then don't like the taste of crow..
