Reverse Light Problem
It's an '04 SuperCrew.
The problem is, when I shift into reverse the lights sometimes turn on and sometimes they don't.
What I normally do to get the reverse lights to turn on is put the truck in Park and then go to Reverse because if I go from Drive to Reverse it rarely works.
This isn't a really big problem but now that I installed a back-up camera, (I had to 'tap' into the reverse light cable in order to 'trigger' the camera) sometimes the camera turns on and sometimes it doesn't.
I noticed this happening a long time ago but it didn't really concern me until now that it's messing with my camera and I didn't really consider this problem when shopping for a back-up camera.
Any input on what might be causing this 'faulty' reverse light issue would be greatly appreciated.
→SOLVED!←
Fixed!
The shift linkage was okay, so was the bushing.
Picked up a DTR sensor (neutral safety switch) for $10 and it seems to be working like it should now!
Maybe the old DTR was worn out or wasn't making good contact or something I don't know.
Thank you @projectSHO89
