Check brake system warning
I have a 2009 F150 5.4 4X4 King Ranch
The following indicator lamps have illuminated have on my dash; the parking brake, the ABS, & the anti sway. This warning appeared at the same time (Check Brake System Warning ).
Everything works except the Anti Lock Brakes. I have the following codes B1596 & B1342.Using the correct OBD Scan Tool, I am able to reset the codes. Then using the scan tool, I can bleed the brakes
