Not charging with new battery and, Alterntor
Old 04-18-2016, 09:46 AM
!!!Jam42Hay's Avatar
I have a 2005 Ford Expedition and it will not charge replace The Alternator and check the wiring, Will not chrge and, The battery light stay on
Old 04-18-2016, 10:44 AM
glc is offline
Please delete
Old 04-18-2016, 02:39 PM
You checked fuses?
Old 06-03-2016, 01:55 AM
Gee po's Avatar
You could have a short to ground. Maybe an exposed wire that is making contact with ground somewhere. Look and see if there are any apparent breaks in wiring insulation anywhere. might be like trying to find a needle in a haystack, but its worth a shot. Maybe try pulling fuses one by one, seeing if it changes anything and if it does, you'll have a starting point where to look.
Old 06-03-2016, 08:59 AM
joe51's Avatar
" replace The Alternator "
Do you mean that you replaceD the alternator?
"and it will not charge replace The Alternator and check the wiring, Will not chrge and, The battery"
If you expect people to help you, you should at least make your request understandable. We can probably figure out the spelling but proper punctuation and proper use of capitol letters would help make your message understandable. As it is, I'm not clear on what you have or have not done.
Quick Reply: Not charging with new battery and, Alterntor
