Tach signal
on
the Tach Signal for Remote Start is not on the PCM.
The 1999 MY specific info I have is not from Ford direct, so use judgement on trusting it.
The Ford supplied install documents, I cannot find back to 1999.
2002 is COPS, so the color code is different, but similar concept to the non Ford one above.
All this is pending what you are trying to do with this tach signal.
- This will not work if you are installing an aftermarket Tach in your truck.
