Gauges quit, no dome light, no chime
I've searched and havent found the right answer. Truck is an 04 F-150 STX 4x4. My gauges, odometer and speedo quit working. The cluster still lights up when the headlights are on and all the indicators (high beam, door ajar etc.) still work. The dome light also quit as well as the chime function. All happened at once. I checked the ecm fuse and it is good. I took the steering column apart and checked the o/d switch wire and it is good as well. I also checked the cluster fuse and it is good. The battery is a couple months old and the alternator is about a year old and all is tested fine. Anyone have any ideas? Thanks!
