Erratic fuel gauge
Erratic fuel gauge
Today my fuel gauge dropped from 1/4 tank to empty and NO low fuel light. Tapped the display and it momentarily showed correctly. It continued to operate erratically until I filled it up. For the next 60 miles it help steady on full.
In the past I had the OD going off and tapping display brought it back. I had read that there was a poor solder joint on the cluster board connector, which re-soldering fixed. As with the overhead compass/temp display.
Could this be the same with the gauge? The display unit isn't the easiest to remove.
2003 F150 XLT
4.6
4X4 Full size bed
228000 miles
2003 F150 XLT
4.6
4X4 Full size bed
228000 miles
