Electrical stuff gone bad?
Have you checked your battery to see if it needs to be replaced? Also check your charging system too. These tests can be done for free at most leading auto parts stores.
I also recommend checking the fuse box to see if water is getting in there. Along with checking the floor pans to see if the windshield is leaking and getting into the electrical.
And, do you know how long you've been having these problems? Do we infer that before this the horn was not working but that the cruise control, lights for the AC and odometer WERE working?
Do you know if you've done any electrical modifications on your vehicle?
- Jack
