Engine swap using 2004 harness
I have 2004 F150 4.6 2v engine, auto trans, PCM, and wiring harness PCM has three plugs that match harness looks like one is engine one is trans and one needs to be thinned out to only what is needed to make things work I have complete wiring manual from ford. At this point I am trying to get this engine trans and PCM hooked up and running in 1950 F-1 any help with wiring would be helpful I have KEY & PATS TRANSPONDER but do not have instruments looking at FORD wiring manual it does not look like I need stock gauges BUT I am old and may have missed something. ALSO looking for someone that can program SCT scanner to delete rear O2 sensors, EGR, Intake control valve and anything that is not required to get me up and running. THANK YOU Steve
