Battery or Altenator
Driving last night, all lights go out, iwds almost engage, airbag and emergency lights come on, engine quits. Pull over as this is happening, passer by give me a jump, I make it home. I trickle charge for 4 hrs. Measure across +- and get 12.3v with engine off. Start engine , measure across +- and get 12.3, holding it on there for a few min, I observe this reading drop steadily to 12.0 volts. I am thinking alternator ...?
- Jack
Well, you're certainly not charging at 12.0-12.3V with the engine running. But, maybe, instead of the alternator itself, how are the connections? Check the connections at the battery terminals, the other end of the negative battery wire, the connections at the alternator, and so on.
- Jack
- Jack
Other members probably have better advice on this option.
- Jack
Jack and Janet, thanks for your advice. I am pretty much convinced it is the alternator. With engine running and no other electrical on (lights, A/C-fan, etc) the volts on my scangauge II reads 12.2. As I turn on lights: 12.0, as I turn on a/c: 11.8. Even revving up to a steady 1500+ has no voltage increase on scangauge.
on
It's obvious that the alternator isn't charging and that the battery was run down completely, but it's not obvious if the alternator has failed.
Fully charge your battery before leaving. Travel so you use the least possible electrical power. Daylight, no lights, no stereo, switch AC to OFF, roll the windows down a bit for ventilation, etc....
You will be running all the mandatory electrical systems off the stored battery power, so preserve it.
on
The following users liked this post:
went to the zone ( i hate that place), they couldn't test because the battery was too low... The battery I have is over 4 years old. I replaced the battery. Same results and readings as before. This morning I removed the alternator and brought it to a local re builder. It will be ready tomorrow.
