Removed automatic remote starter
While removing the autostarter from my truck I accidentally pulled out a wire which was wrapped around the ignition. It was a clear wire which had 2 small black/blackwhite wires attached to it. I am looking for any information as to what that part was and where the 2 wires should have terminated. Diagram? Part name? Function ? etc.... My truck ran well before and now it will not start. I get a click noise under the hood and the engine won't crank. BTW I have 1999 F150 xl with 4.6l. Thanks in advance. I will also enclose a pick I found of the wire from another ford vehicle.
on
Good, that does mean that PATS is happy. You can stop being concerned about the antenna on the ignition cylinder for now.
Now, go find out EXACTLY what is clicking under the hood since we can't see it. Take a picture pointing to it, if you must, so we can identify it.
Was the old system a remote start only or was it also a security system?
When ripping out the old system, did you remove any external relays or other components that had bee installed in series with an existing wire?
