short in ignition sw feed
on
What is a "2007 fleet truck"?
Year, make, model, engine, transmission are the needed identifiers.
Identify the fuse by its reference designator from the owner's manual. If you do not have the manual, get one (see signature below).
Up to a 1/4 amp draw is completely normal until the battery saver circuit times out, some 30-40 minutes after the last door switch or the ignition switch changes state. Do not attempt to troubleshoot without taking that delay into account, otherwise you will waste significant time and effort.
