Driver door wont lock and unlock (electric)
Hello everyone.
I was seeking some advice before I went out and bought any parts to fix this issue I have.
Basically my driver door on my 2002 super crew wont lock. Now when I do try and lock it via the remote or the button inside the truck it will make a very unusual sound like something is jammed.
This tells me that it is getting power. I have taken the inside door panel off and I can move the rod that goes up the inside of the door without a problem. It is only when it tried to lock itself.
Do you think it would need the door Lock actuator motor replacing?
What are your thoughts?
Hello everyone.
Here are a few links ( a sample from many more ):
https://www.f150online.com/forums/el...ighlight=locks
And a How-To fer the actuator: https://www.f150online.com/forums/ar...uator-diy.html
And an FYI: https://www.f150online.com/forums/ar...door-wire.html
good luck
MGD
Best of luck! And - please report back when ye can. If ye still have problems, we'll get the Big Gun Steve Scully on the case
MGD
