2010 F150 Blinker Issues
New to the site, I found a lot of good info so far and am in need of some help... I recently purchased a '10 F150 XLT w/43k and am very happy with this truck so far. When I initially test drove the truck, the blinkers were flickering fast - the hazards blinked normally. I figured it was just a blown bulb so I went through and replaced all the blinker bulbs - front & back. This did not take care of the issue. I replaced the fuse inside the cab, no luck. I have read that I may need to replace the SJB, but would like some input if anyone else has experienced this and may have some additional information - before I start throwing more parts at it or take it to a dealer. No LED's - that I know of, no mirror signal blinkers or fog lights..
Thanks,
Thanks,
Thanks,
Thanks,
Very likely it's the SJB if all the bulbs and sockets are healthy, bulbs are the correct ones, no added-on items attached to the signals, no 'DIY' hacking of the harness, and no B.O.W is evident in the cluster.
good luck
MGD
