Front Parking Sensors
Old 08-31-2014, 12:02 PM
Du4's Avatar
Du4
Du4 is offline
Lately the front parking sensors will go off when I come to a stop. Nobody in front. It's not all the time. What gives?
Old 09-01-2014, 11:41 AM
joe51's Avatar
Only thing I can think of is that front is diving down and sensors are detecting pavement. Have you modified your suspension???????????????????
If not, then perhaps your front shocks or suspension are weak for some reason.
I don't have front sensors so I will ask, do front sensors beep faster as object get closer like the back ones do? If so, how fast is beep rate? That will give an idea of how close object is. You might try unplugging sensors until you figure out which one is detecting object. How long does beeping continue? If it's due to truck diving then they will probably stop beeping once truck stops OR when braking stops and truck returns to level.
Quick Reply: Front Parking Sensors
