Flash to pass does not work, high beams work and low beams work
on
https://www.f150online.com/forums/el...beep-beep.html
Post #10.
What I meant was once you have a wire in hand, where do you place the tester? Do you have to cut open the insulation and press it to the wire?
Before taking the column off, I would also like to know how well the wires in front of you correspond to the ones on the diagram. I do appreciate your input.
Then, say you find a faulty wire. Can that be repaired or do you have to replace a bigger component such as a wiring harness?
If all wires test out, can you please confirm that means it's the MFS.
