ABS Fuse blowing
ABS Fuse blowing
I have a 2002 F-150 4x4 Lariat with a 5.4L. Fuse # 23 keeps blowing in the cab. When it does I loose blinkers and my abs light comes on, but my flashers still work. I have removed a few of the loads associated with this circuit and still have the same problem. The fuse doesnt blow at a certain time such as when I use blinkers or hit the brakes, it usually takes a few minutes to blow. I have removed heated seat#118,four wheel anti lock brake#102,trailer tow battery charger#102and#302. My scanner will not communicate with it. What else do I need to do to find problem.
on
The ABS sensors cannot cause the fuse to blow.
I/P F23 supplies the following items: 4WABS module, ESOF clutch relay, Center axle disconnect solenoids, Trailer tow Battery charge relay, Day/Night mirror (if equipped), Overhead Console, Heated seat switches and relay modules (both sides).
Unplug each and see if the short goes away.
