Alternator discussion for the enthusiast
on
Hey fella's how is everything?
I think I done pushed my charging system to its limit. I have the big "4" wire upgrade, Fresh red top under the hood powering my truck.
But I also have a sound system with a 600 watt 4 channel amp powering my door speakers, and a mono block powering 2 12" ported subs. I forget the power rating of the sub stage but I feel like it is time to upgrade my alternator. I do plan on adding some accent and offroad lighting on my truck so I really do want to get the best bang for my buck. Where should I start looking? Will a 220 amp will suffice my wants/needs or should I look for a 270?
For those guys who know what I should look for please share, I'm all ears!
Thanks guys
Thanks guys
Hey Bro I'm in the same boat. I've upgraded to 4 gauge on the big 4. I have been looking at two different alternators, power hungry bastards and a mechman.
http://www.powerbastards.com/product...navsid2=120925
http://www.mechman.com/index.php/products/g-series.html
I'm probably gonna go with the mechman. Higher output and if you have the money you can get a variable charge rate with adjustment in the cab for when you need the extra voltage. From what I have read they are a custom built unit made to handle extreme output. Beefed up larger bearings and stuff. Most others just tweek a OEM unit. Hope the info helps.
