Help please. No rear tail lights
What about blinkers, hazards, and dash lights? If they are out to, you may want to look a little closer at the fuses. Front running lights? And did you check the bulbs? Its been awhile since I've been into mine, but I think one bulb works blinkers and brakes, and another works tail lights.
Either you haven't found the correct fuse or you aren't checking the fuses correctly.
Do you have an owner's manual? It has a full fuse chart. If you don't, you can download it.
https://owner.ford.com/servlet/Conte...OwnerGuidePage
Fuses need to be pulled and checked with an ohmmeter.
