Battery group size, bigger ok?
Truck originally had a 540cca group 59. I put in my vin on the ford motorcraft site and it showed a group 65. I bought a motorcraft 750cca group 65 and it was definitely longer. But it fit and the oem battery cover also fit over it. Truck starts fine and battery gauge is normal. Will I have any problems with this larger group size?
Went with motorcraft cause my original 540cca battery was still starting fine and that's after six years. 2008 with a oct 2007 build date.
Not sure why I went with a larger cca battery, but it was only $119 and since I gave them my old one, no core charge.
I actually meant group size, as in the demensions of the battery being larger but still fitting in the truck, not the cca. But that's good to know too since I did up the cca, thanks!
Though, you maybe be right. My last battery had the part number bxt-59 and was 540cca. The new one is bxt-65-750. Both have the same width and hight, but the 65-750 is an inch or so longer. All I know is it worked, and my truck cranks in very cold temps like it's not even cold out. The new battery and the added cca add a huge difference.
