Electric Problem appeared recently
I have a constant .23 amp draw on my 1999 Ford F150. When I pull fuse #15 from the cab this drops to around .02 amps. I have experienced problems with a dead battery after overnight sitting. What is a normal amp draw on a Ford F150 with ignition off? I originally pulled fuse 103 from under the hood which led me to the cab fuse box.
New battery installed in June, worked fine to early September. Drove from GA to IL early September. Battery dies again. Replaced battery. Good for a day. Charged battery, parked truck with battery cable unhooked. Starts every morning when cable is attached.
Thanks for the input. Cruse control does work. I am not aware if the recall has been done for that item. I have had a gas tank strap recall and some wire harness done about a year ago. I'll have to find those records. The amp measurements were taken inline from the negative post set on 10A and showing .22, sometimes .23. Truck had been sitting for over an hour with no change in the draw.
We had a break out tester for this purpose. Basically you can make one with a threaded battery terminal disconnect. To check the circuit in sleep mode you can't break the circuit, and then add the meter inline. It has to have the meter inline before disconnecting the main circuit.
It is very difficult to do it without a break out. You'd have to simultaneously hold the meter lead on a battery post, slide the cable up off the battery while holding your other meter lead on the cable.
This is what I was picturing in my head as an alternative that you can probably find locally
http://www.harborfreight.com/media/c...mage_12541.jpg
This is similar to my setup for work, but it has battery cables and terminals off the post of the switch.
http://static.speedwaymotors.com/RS/...91064502_L.jpg
