f150 1992 Brake indicator light in Dash cluster doesn't light.
How do I check / replace the light for the brake indicator on the Dash cluster. Light doesn't come on when the ignition key is turned on, or when parking brake is set.
Truck won't pass state inspection without it.
What is the best way to restore the headlights too? cost of replacement lenses?
Thanks.
Dave
Thanks.
Dave
I checked the connector on the side of the brake fluid reservoir. disconnected it, sprayed it with electronic cleaner, let it dry and restored it. verified the fluid was at the full mark. I verified the connector on the Master cylinder was also tight. hard to disconnect without breaking the tabs. The brake indicator still doesn't illuminate.
