PCM Power Relay??
on
If you don't know what a PCM Power Relay is, you should follow Mark Twain's advice.
If I go into Advanced auto or any part store what do I ask for?
Go to Advance Auto and ask them for a Borg Warner (BWD) # R3177 relay. It's around 12.50 retail and is a generic relay 30A relay. The same relay is used in several other functions in your truck including the fuel pump relay.
So what controls the power relay?????
http://www.quotationspage.com/quotes/Mark_Twain/31
No start pats problems
new to forum and I know thread is a little old but for anyone struggling with pats crank but no start issues here's my experience it may help some. My truck would start when not used for awhile after shutting off it would crank but not restart. Theft light blinking. I replaced fuel pump no change. Before u waste time and money like me check all fuses relays and diodes having to do with pcm. I highlighted in manual all fuses relays and diodes in my manual then started checking. Pcm diode turned out to be rusted switched with ac diode and viola fixed. I spent hours replacing fuel pump and searching for bad grounds but please check both ur fuse panels first Hope this helps someone
