No Speedometer or Odometer 2001 F150
Hello, I have a 2001 F150 4.2L manual transmission (M5OD). Speedometer and odometer are not working. Speedometer fluctuted wildly before it went out altogether. Probably unrelated, but the cruise control went out about 5 months before that. Autozone code reader indicated Speed Sensor, which plugs into the back drivers side of the tranny. I replaced that but still no speedometer or odometer. No fuses are blown. I saw a 2006 thread that pointed out a cold solder problem behind the instrument cluster, but the link porivided no longer works. Can anyone provide detail on what to look for and pointers on taking apart the instrument panel/ dash before I go the dangerous route of trying to figure it out myself?
Thanks!
Thanks!
Greg Upton's excellent HowTo on repairing an intermittent odometer display in 97-03s is a sticky-- the second thread listed at the top of this forum. Right up there ^^
Here's a link to it: https://www.f150online.com/forums/el...er-repair.html
If you have basic soldering skills, you should have no problem. Though it sounds like your truck may have more wrong than just a cracked solder joint behind the odometer display.
speedometer/odometer not working
Well, I just about give up. I followed the instructions from Greg Upton and did find a cracked pin solder, the same one he did; the pin standing apart from the others. I used a magnifying glass and found no other cracked solder joints. I repaired the solder, put it all back together and still no speedometer or odometer. I anyone has ideas, I'm all eyes & ears. Otherwise I plan on taking it to a mechanic. Bummer.
