fuse panel circuit board replacement
2006 xlt/4x4/5.4 sohc/scab. Ok guys....I need to remove my fuse circuit board from under the passenger side dash. I'm going to solder a new fuel pump relay onto the board. Is there anything special I should know about this job (other than removing the battery cables), before I start? I'm assuming I need silver/ROHS solder. My biggest problem, I think, is HOW THE HELL DO I GET THE DAMN THING OUT OF THERE ??? Appreciate the info!
LOL! I figured someone would ask this question first! Why? because I was a moron. I was in a hurry to go through my troubleshooting, starting with the fuses and mistakenly assumed the relay was removable. I damaged it with needle-nose pliers trying to get it out. Yes, I learned the hard way. now I can't go any further troubleshooting until I fix the new problem I created. The dealer only sells the entire board for $275 + and I'd like to get out of this mess cheaper. My main concern is getting the panel out so I can replace the relay. Unfortunately, I doubt many people have ever removed the thing. Even if I buy a new board, I still have to get the old one out, obviously, and I'm trying not to do anymore damage. :o
I did find the root cause of my trouble. Big surprise- the fpdm is cracked in half. It fell apart when I pulled it just a little bit. Hopefully the part will be easily available at the dealer. I see where many guys have had trouble finding one. If i get the relay thing fixed, I'll be all set...
Well, I just found and ordered a relay from an online store - the exact relay, from the exact manufacturer, thankfully. It wasn't super hard to find, but it was hard to find a source that would sell you just one. Unfortunately, I've never seen a late-model Ford truck in any junk yard here in central ny, but I guess I might get lucky by calling a few, worth a try. Both good ideas, thanks!
DD- looks like your lucky day! I'm happy for Ya. I am curious though. You said the relay you need to replace is SOLDERED in. From the pictures on the link, those fuses/relays ALL would seem to be "push in". Is there an additional panel that has soldered in components?
Yeah, I thought the relay was push-in too,but no, this one for the fuel (along with 3 other small ones-black) are soldered directly to the board, in passenger foot well. I took the fuse box apart and cleaned the solder off in preparation for the new relay, which is supposed to be here tomorrow sometime. Boy do I ever know how to make work for myself! had to disassemble every part of the box and remove every fuse (took pics) in order to get to the back of the board to solder in a new relay. Found the part online. The biggest problem getting a new relay was finding a place to sell me just one-most places only sell in bulk.
