7-pin connector not working
on
What is not working on the 7 pin ?
You you using a trailer or a meter / test light to test with ?
When you test the 4 pin trailer tow adapter as good, are you using the ground in the 4 pin plug ?
If you use that same ground ( on the 4 pin ) do the circuits test as good on the 7 pin ?
The 7 pin adapter is the standard RV 7 pin round plug
Not sure what the cover has on it, to comment one way or the other, but the above diagram is correct for a standard 7 pin RV trailer Tow adapter.
When testing watch which diagram you are using ( the plug or the adapter on the truck ), the pins will be mirror images of each other.
