F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 11-03-2009, 12:44 AM
Vehicle: 2000 ford f150
Brights
I own a 2000 f150 and if I flip the brights on the headlights shutoff completely.The dash indicator dosen't come on either.Any ideas?
2000 f150,4.2,5 speed
Old 11-03-2009, 09:13 AM
Vehicle: 2006 FORD F150
Did you check the fuse ?
Did you check the bulbs ( easiest by checking the bulb connector for power with a meter ) ?
Does the same thing happen when using Flash to Pass ( pull back on the MFS ) ?
Old 11-03-2009, 09:22 AM
The fuse is good.I didn't check the bulbs because the indicator in the dash dosen't even come on.Lights shut off even if I pull back.Thanks for the quick reply
Old 11-03-2009, 12:09 PM
If you have confirmed power on both sides of the fuse with a meter, then the only part left is the MFS.
The indicator is on the same circuit as the high beams, so you are correct, if there is power on the high beam circuit, the high beam indicator on the cluster would be illuminated.
Time to remove the MFS and test the switch in it.
Thread on the MFS
Anatomy of the Multi-Function Switch
The test chart :
Old 11-03-2009, 08:40 PM
That's awsome man thank you very much.Will check it out this weekend when I have time.
Old 11-04-2009, 09:57 AM
Just saw I did not paste in this thread
Stopping beep beep
You might need this to get the ign cylinder out, so the upper steering wheel cover can be removed ( without bending the snot out of it ). Just so you have it handy in case. Look for a post by JMC, he wrote up the procedure on how to remove it.
Another quick question, when you checked the high beam headlamp fuse #3 in the cab fuse panel, did you have the headlamps turned on, and the MFS pushed forward ?
A quick test ( if you have a steady hand ) is to apply +12 V DC to the pin in the back of fuse #3 ( passenger compartment fuse panel ) with a meter probe or awl.
To do this, have the truck off, and the headlamp switch turned to the OFF position. Either side should illuminate the high beams if the fuse is good.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
