You can try swapping your battery saver relay with another from the BJB ( aka Battery Junction Box , Engine Compartment fuse panel ) to see if it is a problem with that relay.
That relay will control quite a few things, so this is a guess at the moment.
I say use one from the BJB, as the Battery saver relay triggers another 2 relays in the CJB ( central Junction box, cab fuse panel ) so you would not want to cross the problem somewhere else, if it is that.
Think the 1 of the trailer tow adapter relays is the same size ( full size ISO if I recall correctly ).
