F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 10-17-2009, 01:13 PM
courtesy light DOES NOT come on when door is opened
Hi all,
I have a 1999 Lincoln Navigator and when the driver side door is opened, the courtesy lights do not come on. when the rest of the doors are opened the lights come on without a problem. I thought that it may have been the door ajar switch, but I tried the WD40 trick and then tried to replace the switch after that didn't work and that didn't work either. I am not sure if the relay would be causing this or what... I hear the relay when the other doors are opened, but not the driver side door... Is there something else in the path from that door ajar switch to the relay that could have failed? Any help would be greatly appreciated! Thanks!
Amos
Old 10-17-2009, 02:11 PM
Location: Among javelinas and scorpions near Tucson, AZ
Vehicle: 2005 Ford F150
I'm only guessing here, but the wiring to/from the switch in the door? I think that's the next thing I'd check. I suspect a circuit has to be "completed" to register as an open door, so broken wires or bad connections sound very possible.
- Jack
2005 KR 4x4 SCrew 5.4, "Gott's" style CAI, PHP Gryphon Tuned
Old 10-17-2009, 05:56 PM
Thanks!
I will check that next. i tried swapping the battery saver and courtesy light relays around since they were the same thing and nothing happened... I guess I am gonna have some fun tracing that out...
Old 10-17-2009, 06:22 PM
Vehicle: 2006 FORD F150
I have to go with jack on this one, look for a broken wire from the door to the a-pillar.
This will give you an idea of where I am talking about, if I was not clear
How to fix a broken door wire.
This thread is for the 04+ MY F150, so it will not match your truck 100%, but the idea is the same.
Good luck, let us know what you find out.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
