F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 10-15-2009, 03:29 PM
Vehicle: 2001 Ford F150
OD Switch (Aftermarket) wiring ??s
I have replaced my complete steering column in my 2001 F150 (4R70W) and gone with an Art Carr shifter. I am trying to figure out the wiring for a new OD switch. I have a copy of the wiring diagram in my album-
http://www.f150online.com/forums/mem...h-diagram.html
It is a little hard to see, but the OD switch is the Transmission Control Switch in the center of the diagram. There are 3 wires- a power wire coming from the top of the diagram, and 2 wires going to the PCM. One is from the switch to the PCM, and the other is to the indicator light from the PCM. The indicator light gets power through a 820 ohm resistor that is internal to the switch- you can see the zig-zag line from the left of the box to the lamp.
My specific question has to do with the 820ohm resistor inside the stock switch, going from the power wire to the indicator lamp.
Does anyone know if this is to protect/reduce the current for the indicator light, or if it is to protect the PCM? I was just going to run a small 12V indicator light connected to the stock wires which wouldn't need a resistor, but I just wanted to make sure I wouldn't risk doing any damage to my PCM.
Thanks!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
