F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 10-07-2009, 09:16 PM
Vehicle: 2000 Ford F-150
Window Wipers Problem
So my truck has been having the wipers stay on even when the switch is in the off position. So I read up on here and pulled apart the switch, cleaned and re-greased it and they still stay on. So i looked at the fuse for the wipers-fine. The only other option is the start/park relay under the hood(#202). I couldn't get it out however. Does this sound right? am I missing anything? and am I just not pulling hard enough on the relay?
2000 F-150 XL 2wd 4.2L, 5.5" front 3" rear lift, 33" General Grabber AT2, 130w KC Daylighters, Dual 4' Firestiks-Sig by screenfx
Old 10-12-2009, 09:31 PM
ok so i pulled the relay and got a new one, still the same problem.....any thoughts fellas?
Old 10-12-2009, 10:33 PM
Vehicle: 2005 Ford F150
Quote:
Originally Posted by madmaxwell87 View Post
k, i was wondering what was going on, wasn't getting answers so i tried another section,sorry
No problem, just message me if you want it moved, but I think the elctrical is where it belongs. Maybe someone will chime in.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 10-12-2009, 10:53 PM
Vehicle: 2006 FORD F150
I would say the MFS is the problem still.
Ghost wipers is usually caused by the MFS making contact while in the off position.
Remove the MFS from the steering wheel column, and test it
Don't know how I missed this one the 1st time around
Last edited by SSCULLY; 10-12-2009 at 10:57 PM. Reason: spelling is not why I got the job
Old 10-12-2009, 11:47 PM
No problem, you found it now. So you think its still the switch? The wipers will go faster when pushed to the top two fastest speeds but wont speed up or slow down in the intermittent stages. They wont start on their own, just wont stop when turned on.
Looks like I need a volt meter or test light. So I should just test terminal 4 and 6? Are these schematics of the board you can see when you pull the spring and plastic piece? Thanks for the help
Edit- I did some research on the MFS-I guess ill pull the end of the stalk off again and clean/re-lube it. Looks like I might need to pull the whole thing out and check the connections though
Old 10-13-2009, 12:29 AM
The diagrams above are the connector in the steering wheel column, where the MFS is at.
Here is a thread that shows the MFS removed, you can get an idea of where they pins are at.
You will need a Meter that can measure resistance to test the switch, test light will not work for this.
From the description, it still sounds like a problem with the MFS. Once you run the tests, you will get a better idea
Old 10-13-2009, 01:55 AM
Thanks for all the info
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
