F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 09-16-2009, 01:25 PM
99 F-150 ignition/anti-theft question
Howdy all. I posted this on another forum and didn't get any answers so I came to the source of all F-150 knowledge...
I am new to the forums and hope someone can help me with a problem with my truck. I have a 99 F-150 that won't start. I had 2 keys for the truck, one worked perfectly fine, the other would unlock the doors and ignition, but the anti-theft system wouldn't let it start the truck. My wife has now lost the working key and my truck has been sitting in my driveway for a month or so. When I stick the key in the ignition and turn it, the wheel unlocks and the truck turns over but the anti-theft light flashes and the engine won't actually start.
I have been told my one mechanic that it is a 10 min job to just replace the ignition switch with one that I buy from the local auto parts store. I have had another one tell me that I just need to have the local dealership reset the computer so that it will recognize my key again. I had a 3rd person tell me that even if I replace the switch, I will still have to take it to the dealership for them to program anti-theft system to recognize the new key.
I don't know who to believe. Should I just spend the $80 for the switch and hope that is all it needs? The dealership says they can't even give me price quote till they look at the truck in their shop. I am quite a distance from the Ford dealership, so haveing it towed there is something I can't afford to do right now.
Anyone with knowledge of the ignition system on the 99 F-150 who can help me out with some info?
Thanks in advance.
Robert in NC
Old 09-16-2009, 01:54 PM
Vehicle: 2006 FORD F150
Your truck has the PATS ( Passive Anti Theft ) feature.
The 2nd key might have been cut for the ign tumblers, but never programmed ( due to a missing key, requires 2 keys ).
The truck as it sits needs to have the HEC erased, and 2 new keys programmed to it.
This can be done at the dealer, or at a lock smith that does PATS work ( he would need the PATS programmer, not just a RFID key cloner ).
Try the phone book for PATS lock smiths. I find less of them around, most went to the RFID key clone method of key duplication.
I would imagine a tow to a Ford garage is going to be in order. The dealer is going to need to use the WDS / IDS computer on the truck to erase the old keys, and start with 2 new keys.
While you are spending the money, have 3 keys made, in case this happens again. With 2 programmed keys, you can have a key cut, and program the new yourself ( if it is not a RFID clone, in that case, you are good to go ).
Old 09-16-2009, 03:23 PM
Thanks for the info....
One more quick question. If I have the one "non-working" key, can I get just it reprogrammed to the truck, or will I still have to buy the 2 new keys and have them programmed? If the latter, can I use the "non-working" key as my 3rd key?
Old 09-16-2009, 03:47 PM
The 'non-working' key can be 1 of the 2 ( or as I suggested 3 ) keys to be programmed by the Ford dealer.
You will be into the dealer for 1 hour of shop time ( HEC erase and key programming ) , and they are already cutting 1 key, the cost delta is going to seem minimal to get a 3rd key.
Since you have no idea where the keys went, make sure they follow the procedure for erasing all PATS keys ( else the 2 factory keys count as the 8 total that can be programmed, and those lost keys can still start your truck ).
When they erase the HEC of all PATS keys, the first 2 keys cycled through the ignition are the ones programmed to the truck.
At this point the 3rd will be programmed following the procedure in the manual, or with the WDS/IDS ( hard way at that point IMO ).
Old 09-16-2009, 10:52 PM
Vehicle: 1997 Ford F150 5.4
..deleted...redundant
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 10-05-2009, 11:16 PM
Vehicle: 1999 Ford F150
my ignition housing or ignition lock cylinder broke the other day. I still have 2 keys that worked but there is no hope for the housing itself because the part that actually rotated snapped off in the steering column I fished out after a 20 minute fight but now I don't know what to do. I have looked around online and most places are asking more that $115 dollars for this thing. Is there any way I can by pass the security system and make it work with a simple key to turn the electronic parts on and a push button to the starter.
I realize it may seem like I tried to steal a car, but this is actually my truck and would realy appreciate any advice on what I should do. I just dont want to spend that much money and still probably have to pay for a reprogramming from the ford dealership.
Old 10-06-2009, 09:02 AM
Have you considered buying a new cylinder and getting it pinned to match your existing keys?
Old 10-12-2009, 04:59 AM
I actually went ahead and did that I was able to find some at a fair price. as opposed to the ones on major websites that run you over $115 I found a guy on ebay who's got a shop in Georgia that will get you a new cylinder re-keyed to your key for about $36. great deal.
Wolf Security Hardware just type in lock cylinder on ebay and it should bring it up and hopefully save yall some time and money
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
