Fog lights ON turn the instrument cluster lights OFF?
on
If that is the case, and all the fuses are good, I would go with changing the switch. The fact that the instrument cluster does not illuminate with the parking lamps or head lamps ( and the instrument cluster fuse is good ) tells me the switch is bad.
on
You have a high resistance ground on the fog lamp coil.
Not the best thing to do in general, but the factory route does this through the high beam elements, which is much larger than the indicator lamp, so the high beams do not glow.
The fog lamp relay coil normally gets ground from the high beam element, which with a HID kit, the ability to do that is gone.
If you look at post #11 above, you can see where the fog lamp relay coil derives ground from the high beam element.
You are now getting ground from the Instrument cluster, and that is what causes the glow to the high beam indicator lamp in the cluster.
Here are the 2 method to change where the fog lamp relay coil gets ground from.
https://www.f150online.com/forums/el...aybe-04-a.html
http://www.landstromsfoundry.com/Tec...Foglights.html
I cannot say one way or the other how bad it would be to leave it, but Lyle's method is 2 crimp terminals, and some wire. Small price to pay to not have this happen.
So basically if I follow the steps on the landstromsfoundry.com site I should be ok. The reason I ask is b/c those are the instructions to make my Fog lights stay on with my High beams which I don't have. I take it that these steps also work on a 07. I'm thinking about just buying another HID kit that has high and low beam.
on
Without a high beam element to derive ground from, the fog lamp relay coil is finding the next path ( with more resistance ) which is in the indicator lamp in the cluster.
I would suspect you will have to do this modification if you get a hi/lo HID kit, as the ballast might not have a path to ground, and still use the high beam indicator on the cluster.
The fog lamps are the same on the 04-08 MY trucks, '09 was the next change.
on
From my thread on extending the wiring ( posted above )
In the Central Junction Box ( CJB ) the Fog Lamp Relay is 202, top row of 3 Relays with fuses in between, it is the center Relay.
Rotate this JPEG 90* clockwise to get the correct orientation to the truck's mounting
on
I would guess that is standard disclaimer type stuff, if you don't and something happens, it is a case of you did not follow the directions completely ???
How often do you disconnect the battery to change a fuse ?
