Wire's coming out of wire harness (Windshield Wiper/Turn Signal)
Well Guys,
I am having a problem with my Windshield Wiper/Turn Signal switch for the Windshield Washer motor. I took the old Wiper/Turn Signal stalk off this morning and checked for any broken wires. I didn't find any.
BUT! I did find that after unplugging the harness that some of the wires in one of the harness's wouldn't stay in the holes!
Here are some pictures of it.
They wires have little ends on them that are supposed to "SNAP" into the harness but they aren't. I think I am going to push them all the way in and then put a little "SUPER GLUE" onto the wire end to hold them in place.
What do you guys think?
-Chris
-Chris
on
Don't know if that will do it.
If you put the MFS connector back on the MFS, then insert those wires onto the male terminals using a pair of small needle nose pliers or something else to push the female spade terminal into the connector body, and onto the male terminals, that might work better.
You can try the Ford pigtail catalog, and order one that looks like it. Don't know if you want to go that far or not.
http://www.motorcraft.com/products.do?item=23
You can also try a Napa, they might have the replacement ones. Don't recall seeing this at Autozone, but you could try there as well.
Chris - if you didn't quite catch what SSCULLY was telling you, the fact that the female connectors don't stay in the plastic housing of the connector is really of no importance. What matters is that they securely grip the male prongs in the mating connector (Boy, this post has gotten kind of x-rated, hasn't it?).
If you push the female connectors back into the plastic housing as far as they will go, they will be positioned properly to accept the male prongs. Then, if you sort of keep pressure on the wires with your finger as you reattach the connector, you should get tohse female tabs at least started onto the male pins. If they seem to be sticking out of the back of the plastic connector at all, you might be able to push them the rest of the way on with some kind of small tool.
- Jack
- Jack
Hey luttrell,
I can not thank you enough for this pass. I've been meaning to send this since July.
The day before we had a group heading to a mission trip in central VA, I made the mistake of trying to change the signal switch in my 2001 f150. That night we were supposed to be loading a trailer I was to be pulling with the truck.
After installing the new switch, I tested the switch and found that it didn't work. After taking the clamshell apart to find that almost a all wires had pushed out of the back of the harness. I was in a near panic realizing that trial and error was not going to be possible in solving this problem.
I went on line to see if I could find the harness pattern that may tell the wire pattern. After looking through a dozen or so sites, I was about to give up when I decided to check just one more site... Yours. Thank you so much for posting the photos as it solved our problem. Without it, I would have likely abandoned the use of my truck which would have left us one truck short.
Peace and thanks! Know your post made a big difference to a mission team full of happy kids in Virginia. Happy Thanksgiving and Merry Christmas 2013. I'm hoping you get this since this was back 2008/2009!
The following users liked this post:
