F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 07-03-2009, 02:19 AM
Vehicle: 1993 Ford F-150
93 F150 dash gauges not working
All of my gauges in dash work EXCEPT my alternator and tach..
Where should I start, I checked the connections on the distributor and the alternator they seem to be fine, and the charging system is working fine, could it be that the gauges are worn out?
The odometer reads 315,615 so I am sure they could be worn out as well .. any ideas?
Old 07-03-2009, 02:18 PM
Vehicle: 1983 Ford Bronco
The volt gauge is wired thru the ig.sw. to a fuse that also powers all the other gauges (F.17 - 10A) and goes to ground G200 (passenger kick panel) which also serves the speedo, cruise, RKE, & anti-theft.
The tach is fed by the same fuse thru a different connector in the cluster, which also serves the warning lamps (ABS, 4x4, LOWRANGE, SRS, CEL) & grounds at G201 (driver's kick). It receives its signal on the W/Pk wire from the coil - not the distributor.
No, the gauges don't wear out.
So it sounds like the fault is inside the cluster. Pull it, take the lens & blackout ring off, pop out the gauges & then reseat them to break up any corrosion on their terminals. Use brown paper or a pink eraser to polish the connector terminals for the film circuit. For more info, click my black Bronco in my sig & read the captions in the Low Fuel Light album.
Old 07-04-2009, 04:26 AM
thanks steve will do that asap and let you know how it turns out..
Old 07-05-2009, 03:46 PM
hey steve I was looking through all of your links below and see alot of parts listed, but no prices, are they parts you still have and for sale or parts you had and just a log of them all..
Also can I swap my 93 interior over to a 88 cab? I like the 93 better but the 88 is alot cleaner..
Old 07-06-2009, 12:10 PM
The ones in the Spare Parts album are for sale, but I don't post prices. E-mail me thru my profile here or on SMN & include links to the pics you're interested in.
You can swap most of the '92-96 interior into a pre-'92 cab, but not the dash or steering column (without a LOT of work).
Old 07-06-2009, 04:23 PM
ok thanks again for the info and will be in touch..
Old 07-25-2009, 03:13 PM
I pulled the dash apart but was having trouble getting the shift indicator cable to come undone, so I stopped working on that and fixed my 4x4 floor shift instead.
is there a way to disconnect that so I can pull the instrument cluster out completely and work on it on my bench?
Old 07-30-2009, 12:40 PM
Click the tan CV in my signature & read the captions in the Steering Column album.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
